Browsing this Thread:
1 Anonymous Users
engine flush |
Is it save to use engine flush?
change engine oil today after 5000 Kms. the oil in BLACK color.Very DARK BLACK color. I can see black oil around rockers. So planing to flush the engine. use Liqui Moly is best or just use thinner engine oil to flush the engine?
*There is a carbon stain on the floor from exhaust, in every morning start. The engine oil became black because of the wrong twin SU mixture?
Posted on: 2016/10/30 18:50
Re: engine flush |
Registered Users Contentmaster Usermaster
Engine flush is safe but not needed for gasoline contamination. To clean the oil system, change the oil & filter. Run engine at idle until fully warm, then change it again
basically the same instructions as using Flush, except you save the cost of the flush
Posted on: 2016/10/30 19:18
Re: engine flush |
Thanks. I'll normally use 20w50. Should I use thinner oil for flushing?
Posted on: 2016/10/31 1:54
Re: engine flush |
20W is thin enough. Put 2 liter in , start the engine to flush the bad oil out
Posted on: 2016/10/31 4:03
