Just a quick query guys I'm doing my A15 turbo atm and just wanting to do something a little different mainly because I don't want to cut up a very expensive painted radiator support for an AIR to AIR intercooler. The air to water have great capabilities.
I have found a company frozen boost they make some great products and make a small effective water to air intercooler which in fact I can fit essentially anywhere and just run my turbo intercooler piping
But my main question is, with a water to air intercooler being small (13.5"x4"x3.5", Long Flow) would taping into the normal heater hose line for the A15 water pump have enough power to suck up into the intercooler and go back with no dramas is one question and the second in using the above method will it have a lot of heat soak or will the water still be cold enough being on the intake from the radiator?
here is the intercooler
http://www.frozenboost.com/air_water- ... ir-intercooler-p-220.htmlHere is an image of the intercooler setup on a mazda miata
