Speedometer Alternative To Datsun 1200
From Lisbon
Hi!
I have to change my Datsun 1200 rectangular speedo meter, to a round one to obtain some free space, in this way i can move a round speedmeter to right side. I move it the to right side because i install bmc underdash and the actual rectangular speedmoter fit of speed cable touch the bmc.
I read on forum and im focus on Datsun 280 z speedometer and tachometer. I have 13" wheels
The sppedometer 280z will fit on my actual Datsun 1200 speed cable? The speed will be incorrect? What will be the best alternative speedometer choice?
i read this following setence and What does it means?
"Drill a hole for the trip meter shaft through the back
Many thanks
Luis
jpg  brakes underdash.jpg (28.85 KB)
6267_58fc563b01d96.jpg 640X480 px
Posted on: 2017/4/22 22:40
Edited by Luigi on 2017/4/23 8:08:40
Edited by Luigi on 2017/4/23 8:12:48
Edited by Luigi on 2017/4/23 8:15:24
Edited by Luigi on 2017/4/23 8:16:39
Edited by Luigi on 2017/4/23 8:22:40
Edited by Luigi on 2017/4/23 19:14:53
Re: Speedometer Alternative To Datsun 1200
From Lisbon
Please any ideia
Posted on: 2017/4/23 19:15
Yes, cable fits 280Z speedometer
1. Swap the mounting cups as the 280Z unit is deeper
2. Drill a hole for the trip meter shaft through the back
3. The face is to large for the opening in the 1200 housing, so carefully reduce the diameter by 1/8 inch
Posted on: 2017/4/23 19:41
From Lisbon
Thanks
280z Speedometer will makes a correct read with my 13" wheels? 280z has 14" whells
I will order it on e-bay
Posted on: 2017/4/23 21:18
From Lisbon
Hi!
On Ebay, exists speedometers from Datsun 280z with dual scales kmh and mph. If i set up one of this into my Datsun 1200 the pointer will gives the correct speed reading in mph and Kmh on moment. My doubt is the Kms or Mph on counter counting? It will counts meters and kilometers from the start point to the arrival point?. or count miles
It is possible have a Speed sensor gear? and in this case i will choose a digital speedometer at my choise?
Please let me know
Thanks
Luis
Posted on: 2017/4/24 15:08
Edited by Luigi on 2017/4/24 15:40:16
Edited by Luigi on 2017/4/24 16:54:47
From Lisbon
Let me know something
Posted on: 2017/4/24 21:25
Yes, 280Z speedometer reads correctly with different size tires. The difference is the speedometer cable drive gears in the transmission
There are different 280Z speedometers:
* Mile primary, Kilo secondary (odometer counts miles)
* Kilo primary, Mile secondary (odometer counts kilos)
Posted on: 2017/4/25 7:41
From Biloela, Sunshine State
Hey DD, how would having the drive gear in the transmission help the speedo read correctly? It still can't tell how many revolutions the wheels have compared to distance covered, can it?
Posted on: 2017/4/26 3:47
You are right that the speedometer or drive gears do not tell how many revs/distance. The engineers at the car company figure that out, then specify the appropriate cable-drive gears to be included in the transmission
For example, Datsun 1200
* with 21.7 inch diameter tires and 3.9 final drive: 17T speedometer drive gear
* with 21.7 inch diameter tires and 4.1 final drive: 18T speedometer drive gear
280Z is similar: with different size tires and/or final drive ratios, different transmission speed gears are used
Bottom line: Same speedometer is used with different size tires. The drive gears are changed to match. For Datsun 1200 4-speed, the factory had these gears available: 15T, 16T, 17T, 18T and 19T gears ... allowing you to use different size tires and still have the speedometer read correctly
Posted on: 2017/4/26 4:59
From Lisbon
Hello i bought new gauges to my Datsun 1200 from speedhut
I have on doubt: All A12 A14 Cylinder head has the the same port thread m16 * 1.5? to the temperature sender
THE temperature gauge cames with 1/8 npt female and 3/8 npt coolar nut but doesnt fit
i must buy 1/8 27 npt Female to m16 * 1,5 male, correct? With thin walls
Any sugestion, or where i can find one?
Thanks
Luis
jpg  unnamed.jpg (10.17 KB)
6267_594951ade9344.jpg 240X320 px
Posted on: 2017/6/20 17:47
Edited by Luigi on 2017/6/20 18:49:00
