Browsing this Thread:
1 Anonymous Users
b310 ball joints for neg camber? |
From melbourne
was reading through the tech wiki on how i can get abit more camber in my 120y not for looks but for better handling around corners.
it was mentioned that we can use W50 balljoints from a b310 but does anyone no how much camber the extra length will give?
just say i have +2 degrees of pos camber at the moment where would this put it to?
also i believe i need the late control arms and sway bar as its a different bolt patter right?
thanks!
Posted on: 2017/6/13 11:00
Re: b310 ball joints for neg camber? |
Registered Users Contentmaster Usermaster
To use them you need the 1976-1978 120Y control arms
The downside is they will increase the front track by 30mm. But after installing and re-setting the toe-in, it should move your camber by 2 degrees or so???
Posted on: 2017/6/16 5:32
