A14 bearing condition
Hi. I'm being offered an A14 from a 210gx. Apparently, the previous owners did not change the oil as often as they should. What are your thoughts on the condition of the bearings? To me they seem ok considering the lack of oil changes. Would it be ok to skip on the bearing change?
Posted on: 2018/11/29 18:05
Re: A14 bearing condition
From gold coast QLD australia
They are absolutely pitted and worn out. Put new ones in
Posted on: 2018/11/29 19:42
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
From Hawaii, USA
Bearings are inexpensive. My last set cost $14 on eBay. Easy to put in too. set conrod bearings $21 Rockauto.com
More importantly is the crank worn. Use plastigauge now to check the clearances and a micrometer to check the journals. See our tech article: Bearings. If all is good put in a set of tri-metal bearings (same kind the Datsun factory used F770 type such as Sealed Power CP series}
jpg  journal 1.jpg (151.30 KB)
174_5c00557730363.jpg 1201X801 px
jpg  journal 2.jpg (79.84 KB)
174_5c005580c272f.jpg 1203X801 px
Posted on: 2018/11/29 21:16
Thanks ddgonzal. I will try that first.
As for the bearings, I was hoping to save my self the labor ;). But you're right. I should just rebuild the whole motor. It's already out.
Posted on: 2018/11/29 21:41
Thanks Vixen.
Posted on: 2018/11/29 23:31
