Your engine will last a long time
From Hawaii, USA
The Datsun A-engine is one of the most reliable long-lasting engines ever. Normally they will go 120,000 miles (190,000 km) between rebuilds
But with proper care it will go longer
Posted on: 2019/3/9 22:00
Re: Your engine will last a long time
From Hawaii, USA
What is "proper care" for your engine?
* regular oil changes including filter. Use 10W-30 "resource conserving" oil every 5000 miles / 8000 km. If you live in a cold climate (below 0F/-18C) use 5W-40. See Engine Oil Specifications. Note that oil filters are designed to only last a certain time in hot oil, inexpensive filters are good for 5000 miles. Premium filters (synthetic valve filters) and Full-synthetic oil lasts longer BUT with a carbureted engine the oil will still get contaminated, so change it every 5000 miles
* keep revs up to avoid main bearing wear (worn bearing makes dull engine banging/knock). This means no full-throttle below 2000 rpm (do not lug the engine). Downshift often for example when engine RPM drops below 1200 RPM
* keep revs down to prevent excessive ring wear (so that engine is smoke-free). Ring wear quadruples with RPM so there will be 4x the wear at 4000rpm compared to 2000rpm. Normally shift at 3000 rpm with occasional higher RPM when extra acceleration is needed (as when overtaking or merging onto freeway, rev it up to 5000 rpm for quickest accelleration). If you drive at highway speeds, a 5-speed overdrive is your friend in keeping revs low
* keep it cool to avoid a warped cylinder head. NEVER let the temp get to the "H" line. It is OK between "L" and "H". Check the radiator coolant level before every fuel stop. Replace the radiator if the temp gets to the H line
Posted on: 2019/3/10 21:09
From Melbored
Its one of the best but not the best as that title goes to
the Toyota K series that even with lack of servicing lasts
for eons. It has superior design for everyday use as it is
over engineered from the start and remained that way.
The Nissan A series is a good performer more suited for
track work where good servicing and rebuilds do it justice.
Posted on: 2019/3/11 3:58
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception unknown by dumb Aussies http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
