1200/early 120Y Front Wheel Bearing part numbers
Not too shy to talk
Hi all,
Just wanting confirmation on the front wheel bearing part numbers for the 1200 and the early 120Y (up to Oct '75).
The kits I can find for sale have a different part number for the inner bearing (30205, not 30305 as noted in the tech article). The outer bearing part number matches (30302)
Is it possible that there is a typo in the tech article and it should be 30205?
Cheers.
Posted on: 2019/3/26 5:28
Re: 1200/early 120Y Front Wheel Bearing part numbers
From Hawaii, USA
yes it's possible, looks like it is wrong. I will update it
Type 30305 62x25mm
Type 30205 52x25mm (correct size for B110 & early B210)
Under the "Inner" section where is says Type 30305, I see that most of the bearings listed have 30205 in their number
Posted on: 2019/3/26 5:47
Not too shy to talk
Thanks for the confirmation. Like you, I also noticed that a few of the aftermarket bearings had the 30205 number, and that the 30305 is a larger bearing (62 OD.)
Appreciate your quick response as I'm changing the front bearings in my 1200 Coupe on Friday.
Cheers.
Posted on: 2019/3/26 5:56
