orange 1972 Coupe with 4A-GE engine Los Gatos, California USA
https://sfbay.craigslist.org/sby/cto/d ... oupe-4age/6884792340.html
San Francisco Bay Area (south bay/silicon valley)
It has the large 245mm disc brakes & GTS power!
1972 Datsun 1200 Coupe w/ 4AGE 16V - $14000 (los gatos)
1972 Datsun 1200
fuel: gasoline
title status: clean
transmission: manual
Hello Craigslist,
For sale is my modified Datsun 1200 coupe.
The car has a full power and drive train swap from a Toyota AE86 GTS Corolla. It is basically a 1,600 pound AE86.
I have just recently completed a major mechanical refresh of the car. I had big plans for the project, but I have lost interest at this point and wouldn't mind seeing the car go to a new home for my asking price.
Here is the list of mods (all items marked "new" have been bought and installed in the last few months):
Engine:
- Bluetop 4AGE 16v
- Custom header
- New Gates Racing reinforced timing belt
- New OEM cam oil seals
- New OEM timing belt tensioner
- New OEM water pump
- New OEM cam cover gaskets
- New Koyorad aluminum racing radiator (latest design)
- New thermo-switched SPAL fan
- New radiator hoses
- New OEM thermostat
- New OEM thermostat housing to block water pipe and o-rings
- New injector o-rings and caps
- New NGK plugs
- New NGK plug wires
- New cap and rotor
- New alternator
- New accessory belt
- New starter
- New OEM oil fill cap
- Greddy catch can
- K&N air filter
- New OEM oil filter and engine oil change (Rotella)
- Full OEM GTS wiring harness for engine and cabin
- OEM ECU
Drive train:
- T50 AE86 GTS 5-speed transmission (shifts smooth)
- T3 short shifter
- New transmission oil (Redline)
- Custom driveshaft rebalanced and inspected at Southbay Driveline
- Modified '78 Corolla SR5 LSD rear end (basically a Zenki GTS LSD rear end but with drums)
- New diff oil (Motul)
Front Suspension:
- Front strut bar
- T3 camber plates
- 280ZX shortened strut housings w/ Ground Control welded perches, sleeves and collars
- New Koni yellow sport adjustable shock inserts
- New Hyperco 275 lb coilover springs
- B210 tension arms
- B210 lower control arms
- New OEM lower ball joints
- New SuperPro poly lower control arm bushings
- New SuperPro poly tension rod bushings
- New SuperPro poly front sway bar bushings
- B210 front sway bar
- New center drag link
- New inner tie rods
- New outer tie rods
- New SuperPro poly idler arm bushings
Rear Suspension:
- New Koni yellow sport adjustable shocks
- New Maddat reverse eye lowering race leaf springs with built in anti-tramp (ordered direct from Australia)
- Custom 1" lowering blocks
- New SuperPro poly leaf spring eye front and rear bushings
- New SuperPro poly chassis side leaf spring mount bushings
Brakes:
- B210 front calipers
- New pads
- New front and rear rubber brake hoses
- Wilwood front to rear proportioning valve
- Rear '78 SR5 drums
- New rear drum cylinders
- New rear shoes and hardware
- New rear drums
Interior:
- Recaro SPG racing seat for driver
- Schroth Rallye harness
- OEM AE86 GTS passenger seat & seatbelt
- OEM AE86 GTS gauge cluster (everything works)
- OMP racing pedal set
- MOMO steering wheel hub
- T3 Odyssey battery bracket
- New Odyssey lightweight battery
- New window channel seals
- Crack free dash
- Nice door cards
- Rest of the interior is stripped out
Wheels:
- Custom ordered 13" Libre wheels
- Federal Super Steel tires
Includes:
- New Maddat steering box brace
- New windshield seal
- New rear window seal
- Whole set of spare coupe doors, complete, and usable as replacement doors if needed
- Great condition factory metal hood
- Great condition spare passenger front fender
- Excellent condition rear chrome bumper
- Set of exterior chrome window trim (rear quarter window lower trim, upper rain gutter trim)
- Set of spare complete rear taillights
- Set of spare chrome side vents
- Set of spare rear license plate lights
- Spare side markers
- Spare rear quarter windows and latches
- Spare door hinges
As you can see, I've basically gone through all the mechanicals of the car over the winter. It's a great running and driving car at this point. The body does have some dings, dents, and scratches. There is also rust damage on the car, but it has been treated and patched. No active rust. The next phase for me was to do flares, wider wheels, front and rear spoilers, body and paint.
It's a rare car with a great swap that solves all the power and drive train rarity / aftermarket support problems with this platform. Lightweight, rear wheel drive, legendary twin cam 4 cylinder engine, 5-speed, and a LSD - it's a great package to build on.
If this ad is up, the car is still available
jpg  left.jpg (60.33 KB)
174_5cf354f3a69b2.jpg 600X450 px
jpg  16V engine.jpg (55.65 KB)
174_5cf354fcdccc7.jpg 600X450 px
jpg  right front quarter.jpg (44.33 KB)
174_5cf355031bc46.jpg 600X450 px
jpg  recaro & momo.jpg (40.82 KB)
174_5cf3550a19b2a.jpg 600X450 px
jpg  right rear quarter.jpg (41.97 KB)
174_5cf3550fc432d.jpg 600X450 px
Posted on: 2019/6/2 5:48
