How to identify twin hitachi carbs
From Hawaii, USA
smariese wrote: hi huys..
I am getting flat top twin su carbs and manifold for a series and L series. the manifold and the carbs not attached. now, how to identity which carbs for A series and which for L. the jet and needle size is different for A compare to L?
please advice.
Posted on: 2019/6/25 6:26
Re: How to identify twin hitachi carbs
From Hawaii, USA
Hitachi sidedraft carbs (SU-style) are almost exactly the same A-series and L16/L18 versions
The material differences are:
* L-series has stronger Suction Spring
* A and L use different needle valve
And the practical difference is in the throttle linkage. A uses cable linkage, L uses rod linkage (as far as I have seen)
There are only two Suction Springs. So that's an easy change. However there are many needle valves.
* I would change the spring and just run the L valve to start with. There are many adjustments you can make. The A valve is for a stock-spec GX engine (hi-rpm, large port)
* If you have totally orginal GX or A12T engine (including the cam and exhaust system) then it would be worth sourcing the GX/A12T needle valve #M75
Posted on: 2019/6/25 6:39
Many thanks for the reply..
Posted on: 2019/6/25 6:42
yes. the suction spring of A series carb is soft compare to L16.
jpg  twin su.jpg (109.56 KB)
17554_5d197ada909ae.jpg 584X438 px
Posted on: 2019/7/1 4:16
http://datsun1200.com/modules/mediawi ... p?title=Hitachi_Twin_Carb
according to the above link, the a)flat top b)without IMS c)2 bolt carbs are nissan competition carb?
Posted on: 2019/7/1 4:33
From Hawaii, USA
British SU dome springs
* Yellow, 8oz part number AUC1167
* Red, 4.5oz part number AUC4387
* Blue, 2.5oz part number AUC4587
Not sure which is closest to L-series Hitachi dome spring
Posted on: 2019/7/1 4:34
i got part numbers for twin su needle and nozzles from a friend.
needle: 16354-A8710 / 16354-U0810
nozzle: 16355-H2310
are these correct numbers?
Posted on: 2019/8/18 3:35
From Hawaii, USA
Nissan sold many needles for different engines. A87 = Needle #M76 is for L18 engine. U08 is the AMC for Datsun 610 SSS. The A12GX needle is M83 (Nissan part number 16554-H2316)
Nozzle is 16355-H2310
jpg  hitachi_m87.jpg (190.79 KB)
174_5d592d4106e36.jpg 640X480 px
Posted on: 2019/8/18 11:49
