Browsing this Thread:
1 Anonymous Users
Dogleg Speedo gear questions |
Not too shy to talk
From Seattle, Washington
Recently I installed a 63 series 5 speed, after doing so so my speedo is now reading Crazy fast Looking through the wiki, its says that the 63 may use a different speedo gear than the. others? Im currently running approximately 20% slower than said (Says 80+ at 60+0. Tires are 185/60/13 Question , what gear to hunt down? Anybody else go through this combo ? Thanks
Posted on: 2020/8/17 0:42
Re: Dogleg Speedo gear questions |
You need a pinion with ~20% more teeth, i.e, about two teeth more than what you are currently running. Part numbers are here (Note 63 series part numbers are different to 60 and 56 series): http://datsun1200.com/modules/mediawi ... p?title=Speedometer_Gears
Posted on: 2020/8/19 12:26
