Smog inspections, what a nightmare. What is the Colorado law say about exemption? Here in Ca, cars made 29 years ago are exempted(yes, 29, the law as of today, says, after jan 03, cars made after jan 74 are exempted,and in the same way cars made after jan 75 will become exempted afeter jan 04...etc)... so yours probably is close to exemption. The 32/36 carb is a good choice (DCOE is better but the 32/36 is smog compatible). the DGEV 32/36 can work and is aproved by state law (in CA) so, check it out.To use the twin DCOE's, a cam would be a requierement, so that the engine would use all the benefits of its performance(the DCOE's perf).A single DCOE would be cool, but the DCOE will not pass emissions tests, at least the visual inspection. The 32/36 I got, (I was ready for the twin DCOE's , but the prospects of taking them off, and all that for emmisions test made me go for the DGEV 32/36 Weber, still a very good choice, excelent performance, reliability and easy tuning and maintenace.)... works very well.I had no problems with the prospect of taking off the DCOE's and replace the stock carburetor for the tests, but the cam, which would be needed for the performance of the twin DCOE's was a problem, I did not want to take the cam and change it, so I waited untill now, my car is supposed to become exempted after this last smog test I am going through...(yes, "Going" through, because the battle is not over, the smog guys are trying to stop me from achieving exemption, too bad for them, it will never happen, they will go bald before they take my car to the burner!)... soon the nightmare will be over, and my A15 will see the life after death!, yes, its been in coma for all this years, but with a cam and twin DCOE's, it will get to know what life really is about.
Back to your Austin, a 32/36 Weber DGEV is a good choice, gives good performance, check
www.piercemanifolds.com The DGEV will not dissapoint you, unless you choose to go FI, but I do not know if FI was a US A12 standard for the emissions tests.
Jaime.
Check
www.piercemanifolds.com or any other sources you may have, this guys sent me my Weber with no delay, good source, honest people.
Jaime.
