Browsing this Thread:
1 Anonymous Users
The OG Electric Blue Datsun |
Registered Users Contentmaster Usermaster
It wasn't the first electric-powered Datsun 1200, but this early example was one of the first -- and one of the best
Built for commuting to work, it can do 55mph and cost a penny a mile to run back in the 1970s, about 2-1/2 times cheaper than gasoline
Yes, it still exists and was sold back in 2016
Posted on: 2023/5/16 0:21
Re: The OG Electric Blue Datsun |
From MOOROODUC. Victoria
Very nice ... and good to see they kept the battery
Posted on: 2023/5/16 8:06
Red 1200 Coupe (Build: DEMAC's 1200 Coupe) Blue 1200 Ute, CA18DE Auto (Build: DEMAC's 1200 Ute) Green 1200 Sedan (Build: Kermit the beat up sedan) Green Sedan #2 (Current build: DEMAC's 1200 Sedan) Brown 4 door AUTO Sedan for sale...
Yeah looks like a vintage battery In 1979 it used a Trojan 12-volt battery up front, but the main power pack was a dozen six-volt batteries, presumably deep-cycle type. Trojan is still a major supplier for forklift and golf-cart batteries Eight were in the trunk/boot. I wonder where the other four were located
Posted on: 2023/5/16 19:10
I wanted to use the Trojan batteries for a trike project but about 10 years ago were bought by the largest Chinese battery company almost same time as Volvo was.
Trojan made in the USA were very good quality units, unlike the Chinese ones which have complained about on ev forums where now lithium is the only choice and still come from China but are proven units
Posted on: 2023/5/17 14:04
Here is the article from October 1979 issue of Popular Mechanics magazine Quote: How I built my own electric car by Bill Williams
A couple of years ago I decided to be ready for any shortage of gasoline and considered converting my 1972 Datsun sedan to electric. It didn't take long to learn that the technology was available. I joined the local Electric Auto Assn. (EAA), whose 50 members have already converted over 20 autos to electric.
I was still a bit apprehensive about tearing apart a perfectly good gasoline car that was getting over 33 mpg in town. But fate played a part when the Datsun blew its head gasket. I decided in favor of conversion to electric rather than put more than $700 into it (the rings were also going) only to still be dependent on gasoline.
I went ahead full speed. First to go were more than 375 pounds of gasoline-related components (gasoline tank and lines, tailpipes, muffler, radiator, smog control, heater core, alternator, voltage regulator, starter, air cleaner and engine block). Nongasoline-related systems, like steering, brakes, hydraulic clutch, rear end, shocks, and interior components (like the speedometer) were left intact. The back seat was also retained for passengers (though with less legroom space to accommodate four of the total 12 propulsion batteries).
The truck compartment was then prepared for eight 6-volt (244AH) Trojan golf-cart batteries, weighing a total of 592 pounds. One extra leaf spring was added to the rear member to support the extra weight. Two safety devices were also installed in the trunk, a 400-ampere fuse and a large switch that could be manually turned off from the driver's seat. These two safety devices were then wired in series with cables routed beneath the car to the engine compartment. The trunk was finished off by installing the batteries (with steel clamp-down rack) and an electric plug in place of the gas-tank filler. Refueling would henceforth be with electricity.
While I was working on the trunk compartment, a fellow EAA member, Bob Steinfeld, was working on a special "adapter plate" for coupling the existing four-speed transmission to the d.c. electric motor (a 30-hp 2CM77 aircraft starter-generator). The adapter plate had originally cast to fit a Volkswagen transaxle, and therefore required custom machining to fit the current Datsun transmission. I considered retaining the four-speed transmission (plus reverse) a must, not only for flexibility, but also for the efficiency several forward gear ratios (3.757, 2.189, 1.404 and 1).
Attach file: popmech197908_.jpg (96.07 KB)
Posted on: 2023/5/18 12:59
EAA back then ahead of their time, the real deal not like faker actor fElon Musk who just bought the Tesla tech from founders/creators Martin Eberhard and Marc Tarpenning.
Love to see this car survive another 10 years and get upgraded to carbon air batteries. Already in pacemakers for a decade and now in iphones, they contain no Li, no cobalt, just nano carbon and air that can eventually be designed into the structure of vehicles.
Watch Felon sell his Li factories like wild fire as nano carbon production starts to ramp up even BMW and other makers are investing in Carbon air.
Posted on: 2023/6/6 2:09
