RWD gear box for a SR16 engine
From Auckland, New Zealand
Hello all,
I’m considering buying a SR16 engine and transplanting it into one of my coupe’s.
Does anyone know of a RWD gearbox that will bolt up to one of these or at least take minimum modification to bolt up?
Any input or advise is welcome.
Thanks
Brent
Posted on: 2003/3/10 1:21
Re: RWD gear box for a SR16 engine
From Sydney, Australia
You'd be best to get a SR20DE or DET gearbox. from an S13/14/15 Silvia.
The front wheel drive manifolds and distributer could cause headaches. You'd be better off to use a RWD motor. Unless you have the expertise to use the SR20 bits on the SR16..I was thinking of doing it to an SR18 from a late model Sunny..
Posted on: 2003/3/10 10:40
