Stanza
From Christchurch, New Zealand
I believe the stanza with the required front struts is model no. A10, is this correct?
Could somebody post a pic or point me to a pic in the library?
What is it called here in NZ?
Posted on: 2003/4/28 11:52
Re: Stanza
From Warwick, QLD
All's I did when I got mine was look for big calipers with Girlock stamped on them then I checked underneath the ball joint to see if it had 4bolts.
Cheers
damo
Posted on: 2003/4/28 13:19
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Stanza
The problem is I don't think we got a model called stanza here in New Zealand so if I had a pic of the car I may be able to find it.
I also doubt we would have girlock calipers, I'm not sure we had local content laws like you guys in OZ.
Posted on: 2003/4/28 13:35
Re: Stanza
From Melbourne, Australia
yeah stanza is a10, i think girlock is an aussie company so you might have trouble getting them
Posted on: 2003/4/28 13:57
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Stanza
From Millgrove Vic OZ
In NZ its a 160J SSS. Same as A10 stanza except calipers an discs.
Posted on: 2003/4/28 14:40
Re: Stanza
From Newscastle, Australia
Are the strut setup on the Stanza the same as on the 200B's??? I have 200B brake setup with Girlock calipers, and they are apparently the same part # in the DBA catalogue. I have 200B strut tower mounts as well. If anyone has a compatible setup which is fully adjustable for racing please PM me as I am eager to pick up a set for my 1200 coupe.
Posted on: 2003/4/29 0:47
