adjustable cam pully
From durban, south africa
hey guys,
can you get an adjustable pully and cover for an A-12? and what sort of price would you pay?
many thanks
nicholas
south africa
Posted on: 2003/7/8 15:44
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: adjustable cam pully
From Millgrove Vic OZ
Roller master adjustable cam sprockets and timing gears are $200 a set. The just replace the stock gears.
Posted on: 2003/7/8 22:56
Cheers Feral
Not much good to you, I know, but I have a jig that I made for drilling 6 extra holes in the camshaft sprocket. Its available for locals to use when required.
This gives a hell of a lot more options that the original.
Datrally in Cheltenham will sell you one for about AUD70-00 change-over.
There's gotta be somebody in South Africa who can do the same.
Posted on: 2003/7/8 23:56
What sort of performance did the gear give you? I have a turboed A14 with a standard cam but I have been looking around for new one or maybe an adjustable gear would be another way to find higher performance. And then I'm not confind to one tune level. I work just down the road from Cheltenham and could make to trip down there for a talk to the boys.
Posted on: 2003/7/9 0:28
GO DATTO GO!!!
From Sydney
Any chance of a part number ?????
My local outo one guy is unable to find any reference for this part.
On the other hand, he has no prob finding a reference for the standard replacement sprocket.
Cheers
Benny
Posted on: 2003/7/9 2:55
only for V.W engines. i cant even get stiffer valve springs here what a #### hole
Posted on: 2003/7/9 6:15
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
From Little Rock, AR
Here's an adjustable cam sprocket from Tomei for around $150 among some other nice goodies for Nissans
http://www.tomei-p.co.jp/_2003web-catalogue/efr_index.html
Posted on: 2003/7/9 8:09
From sydney australia
benny,try lnyx corporation at rhodes on 02-9767-4800 for the rollmaster timing chain,i was there tuesday & they stock the chains,so they can probably give you a part number,if not sell you one.they also have the $80 twin valve spring sets there,plus they stock arp bolts,but don't want to know about getting me a set of studs,the losers.
Posted on: 2003/7/10 10:56
