cams
From manawatu nz
hi all,
im rebuilding an engine i got hold of, its got a cam in it that i dont know/cant find the specs on it. Im hoping someone here will know. its got CMRRR 3CD written on it. iv'e been told its from cook motor racing nz.?
thanks in advance
Posted on: 2003/8/12 11:07
Re: cams
From Wellington New Zealand
The 'CMR' does make it sound like a Cook one...
If you ring Reg, he may remember, although he's forgotten more things than I'll ever know..
If you have access to a dialgauge and a lathe, you could measure it up for lift, and with a little messing around with bluetack and a degree wheel get an idea of the duration...
Posted on: 2003/8/12 22:34
Re: cams
Not too shy to talk
From Wanganui, New Zealand
Yep ive got a cam similar to that, its a cook motor sport road/race cam. If they've done their job right you should be able to ring them up and quote the stamps, they should then be able to provide you with the spec sheet they made origially.
Alternitively Take it to a engine builder or C.S.l/ kelfords and they'll sort you out.
Posted on: 2003/8/13 0:01
Re: cams
From manawatu nz
datto8u whats the characteristics of your cam is it a pig to drive?
Posted on: 2003/8/13 6:58
Re: cams
Let Brendon at CSL measure it up, he did one of Reg's ones for me a few years ago. It helped me and helps him build a collection of cam specs and he's a 1200 nut as well...
Posted on: 2003/8/13 9:10
