valve springs
From durban, south africa
hey guys,
could someone please get me prices for double valve springs for a 1200, and how much it will cost to ship,post to south africa.
many thanks
nicholas.
p.s will they allow me to rev higher?
Posted on: 2003/10/2 7:49
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: valve springs
From Millgrove Vic OZ
Nicholas,
Depending on brands between $80 - $100AUD and about $20 -$25 AUD to ship by economy air. Approx figures on freight.
Posted on: 2003/10/2 12:16
Cheers Feral
Re: valve springs
is that for a set or each?
Posted on: 2003/10/2 13:28
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
Re: valve springs
A set!
Posted on: 2003/10/2 21:45
Cheers Feral
Re: valve springs
Not too shy to talk
From Townsville, North Queensland
Can you use L motor dual spings in an A motor succesfully??
Posted on: 2003/10/3 4:54
later Allan
oldcorollas
Re: valve springs
can you please tell me what car i can get them off.
thanks
nic
Posted on: 2003/10/3 12:49
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
Re: valve springs
These are special A series springs and do not suit anything else. You could also use A series GX springs , they may be easier to get?
L series springs dont fit.
Posted on: 2003/10/3 23:08
Cheers Feral
Re: valve springs
From Canberra, Australia
A thread resurection!
Ummm same thing with me.
Just some simple questions:
Double valve springs will do what?
Where would I buy said double valve springs from?
Are they easy to fit?
Posted on: 2003/11/18 14:12
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: valve springs
they reduce valve bounce, allowing you to rev higher!
Posted on: 2003/11/18 14:16
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
Re: valve springs
From Okinawa, Japan
Double valve springs prevent high rpm oscillations that can occur at a certain frequency (or rpm) with a certain spring rate. Since the inner and outer springs have different rates, they will counteract the oscillations.
Posted on: 2003/11/18 14:18
