going 1400
From durban, south africa
i have now made up my mind, time to throw away my 1200 and put a 1400 in.
ive got one at a very good price and cant let it go.all it needs is a dizzy and inlet manifold and the guys asking R500.00
what do you think?
Posted on: 2003/10/7 12:32
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: going 1400
From Melbourne, Australia
1400 is heaps better!
Posted on: 2003/10/7 12:35
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: going 1400
i have finally given in. it must be done!
Posted on: 2003/10/7 12:39
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
Re: going 1400
you wont regret it!
Posted on: 2003/10/7 12:42
1200 Coupe Rallycar
Re: going 1400
Quite a regular
From Greece Athens
That's exactly what i'm doing now on.
As you see in my foto it's my new 1400
Posted on: 2003/10/7 14:24
Always Tuned
Nissan B310 '81
Re: going 1400
Quite a regular
From Greece Athens
Sorry I was talking about my avatar
Posted on: 2003/10/7 14:26
Always Tuned
Nissan B310 '81
Re: going 1400
From campbelltown (sydney) australia
wats better in a road car a worked a14 or worked a15? i will probly end up going a series all though id like to get a 12a rotar but i dont know much bout em, and a15 bolts up to evertything
Posted on: 2003/10/7 14:42
Re: going 1400
1400 cc, Extractors, Weber 32/36, 30/60 cam, and some work on the head will make a top road engine.
Yeah---go for it!
Posted on: 2003/10/8 0:09
Re: going 1400
1500, although i havent had a 1400 running, the extra torque and less revving make it faster and more pleasant, so the theory goes
Posted on: 2003/10/8 0:26
1200 Coupe Rallycar
Re: going 1400
A14, or A15? Decisions, decisions.
With all things being equal, the extra 5mm of stroke in the A15 "should" result in more torque. This in turn results in greater flexibility, or the ability to hang onto whatever gear that you are in when under load, such as when hillclimbing, or towing / carying a load.
I run a stock 1200 diff center in my 1000 sedan with the mildly modified 1200GX, 1 to 1 five speed & 13" wheels. With this combo i was forever looking for another gear.
A 1500 would benefit more from an overdrive box & / or a higher final drive ratio as it would have the torque to pull it better.
At my age, torque is regarded as a good thing as my enfeebled arm doesn't flick the gearlever like it once did.
The A14 is every bit as good an engine & will have the ability to rev a little higher, although it is all a bit academic as any of the A series can rev quite well enough to satisfy any road car need.
If you have an A14, then use it, & you will be more than happy with it as they are a great engine, & hey, all you are doing is upgrading to the stock "Bakkie" specs, so even the factory says this is good.
The engine thats going into my KB10 will be a little over 1400cc,[A12] but i need to come up with a diff center that bolts into my stock rear axle that has a ratio a bit taller than 3:9 to 1. Somehow, i don't think one exists.
Chris
Posted on: 2003/10/8 23:08
