Sway bars
From Okinawa, Japan
Will Sunny sway bars fit a ute? For that matter what other sway bars do you guys know of that will interchange without too much hassle?
Posted on: 2003/11/12 13:30
Re: Sway bars
Not too shy to talk
From Sydney, Australia
The sunny swaybar doesn't fit 1200s. I remember trying it. I think the shape was slightly different and the sunny has a slightly wider track than the 1200.
Posted on: 2003/11/12 22:31
Re: Sway bars
From Auckland N.Z
120y is a straight fit and bigger (22mm), its the cheepest and best swaybar upgrade
Posted on: 2003/11/13 0:45
Re: Sway bars
Not too shy to talk
From Canberra
I have a 120Y swaybar which went straight in.
It's 20mm thick. Can't remember the thickness of the original.
Posted on: 2003/11/13 0:47
I'm growing old,
not growing up
Re: Sway bars
From Perth W.A
go the 120y one mines great
Posted on: 2003/11/13 1:00
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: Sway bars
From Canberra
try www.whiteline.com.au,
they can make em up for you
Posted on: 2003/11/13 4:26
Re: Sway bars
From Adelaide, Aust
If i remerber correctly the standard sway bar thickness is 17mm so the 120Y is 3mm thicker which is nearly 20% thicker than standard, and their relativerly cheap and easy to come by making it a good alternative to the more expesive upgrading.
Posted on: 2003/11/13 11:50
It's a way of life
Re: Sway bars
From Okinawa, Japan
Thanks for all the replies. Anyone tried the back? Wish there were more 120y's in the wreckers here. The search is on.
Posted on: 2003/11/13 13:22
Re: Sway bars
. As far as I know, 120Y/B210 Datsuns do not bring a rear sway bar, you will have to fabricate one, and following the 1200 sway bar diagram in the tech section, I think that is the best kind, with no sway bar links, just straping the ends of the bar (eyeless, no link, no need for eyes at ends)...with brackets. Another system that works in rear leaf sprung cars, not as effective but with good results is those traction bars, like the hot rodders cars have, if positioned close, almost touching the springs(rubber ends), act as sway bars by preventing the outer side of the car from sinking in onto the ground, because the leaf spring has no way to go, gets stopped before the body can lean down on the leaf spring, flatening it. The less that perfect part is that on the other side, where the body separates from the suspension(inside wheel)... the traction bar does nothing about holding the body to the axle/suspension, allowing the spring to curve upwards as the spring / axle arangement hangs off of the body while this body is going upwards. I am trying to make a system where the traction bar will hold to the body with one or 2 strong small coil springs, so, the side going up will be held in place, but not tied...( that is why I think about the coil springs instead of just bracking /bolting))...so then the effect of a sway bar will be achieved, and at the same time, a traction effect. The sway bar has that dual action, pulling on the inside body and pushing up on the outside.
Jaime_______________________
Posted on: 2003/11/13 21:19
