speakers for a ute
Not too shy to talk
From sydney,aust
what size speakers has everyone got in their ute??
where did u put them?kickpanels?
not much room is there,trying to work something out,need some ideas.
Posted on: 2003/11/23 0:45
Re: speakers for a ute
From Tas
I've just got a set of 6 inches in the door skins running off a single head unit - I was actually quite impressed with the sound as its only a small cabin.
Depends what you want - personally I'm not a huge car audio freak, I just wanted some tunes - but as I said I was quite surprised.
Posted on: 2003/11/23 0:52
Not too shy to talk
From sydney,aust
yeah not an audio freak either jus need to hear my music over my carbys.the stereo i got now is not the best.
will look at doors thought window would hit on the way down. thanks
Posted on: 2003/11/23 1:01
From Tas
No they don't usually hit because of the quarter vents. This means you have more clearance in the door where the door glass runs down. I got away without using door pods or anything.
I bought a high quality set of 6's and I'm still surprised at the bass they put out. It all sounds nice and crisp and clear.
Make sure you spend a bit of time sound deadening the inside of the door and stop all the rattles etc inside the door before the door trims go back on - you can learn from my mistake cause I didn't think they would be that loud
Anyway I'll get around to it one day..........along with everything else.
Posted on: 2003/11/23 1:15
From campbelltown (sydney) australia
u can get away with fitting 6 inch two ways behind ur seats, juts gotta make a speaker box that is fairly thin. its a bit baffled but u fade more power to the back and u get real good sound., just make sure if u have drivers seats that slide dont have it completely back or u will dent the front grill like i did haha.
Posted on: 2003/11/23 3:49
From Canberra
Heya,
I am running a two channel kenwoood amp, a pioneer head deck and kenwood 3 way 6x9's in the doors.
If you take off the door panel, you can see (drivers side) that the bottom left has a section cut out already. Just use tin snips and a file to cut out a section so the 6x9's fit in and away you go.
The doors are quite deep and so a shallow/medium set of 6x9 fit and the sound is excellent.
Posted on: 2003/11/23 5:13
From Okinawa, Japan
I've got 5 1/4's in the kickpanels and 6X9s in boxes behind the seats running off the deck. Sounds great but like you guys said... I too am not a car audio freak.
Posted on: 2003/11/23 6:07
From newcastle, NSW
I've only got a kenwood head deck and a set of kenwood 6x9's, seeing that the cab is so small you don't need a big stereo not unless you're one of those people who spends way too much money on stereo equipment, tring to impress everyone.
Posted on: 2003/11/23 7:08
From Brisbane
i have mp3 headunit pinoeer, 6x9 kenwood 3ways in the doors, sound stream component 6inch in the kick panels and a kick amp under the seat
Posted on: 2003/11/23 7:36
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Canberra
Quote from Steveo: "seeing that the cab is so small you don't need a big stereo not unless you're one of those people who spends way too much money on stereo equipment, tring to impress everyone"
Maybe its not a case of trying to impress everyone. A cheap and very effective 2 channel amp can cost as little as $120 and rather than providing sound that tries to "impress" everyone is clear and sharp.
Posted on: 2003/11/23 23:40
