questions
Quite a regular
ok ppl i know how many posts there are about utes. ive sat here for hours reading them but i still have questions that im not 100 percent sure about. so if u guys have the time to answer,me and probly many other will apreciate this..
some of u would know i have a ca18det putting out about 300fwkw in a 180sx i wanted that to go into my ute but from looking into it i dont think it would be able to be street driven.so heres my plans i want opinons on what u guys think ( im looking at a stock ca18det will bigger turbo ect)
i know i can get a crossmember from maddat but not 100% sure what box i should be using i dont want to mod the tunnel or move the shifter from where it already sits. now with the motor mounted ill be getting a ma70 cooler and new custom radiator so thats not hard.. but not sure about getting the cltuch to work what will i need?? now for brakes and suspension i want to run disks front and back what struts can i use that have disks that will bolt straight in (once there in i can then put slotted brakes on ect ) ... im going 2 get a diff shortened was looking at a hylux but they are drum from what ive been told is this the way to go or is there another diff (lsd) that i should be using that has disks on it so i can have 4 wheel disks????... also what tail shaft should i be using? custom 3" maybe?....... now whats the best way to set up the suspenxion so i have good control and minimal wheel spin ? has anyone wired up a stock ca18det computer to a ute i know it can be done cause power and ground wont be hard then wire it 2 a fuel system and ignition barrel.. am i forgeting anything?? also im after a new tank i wanted it mount in the tray ( one of those black plistic ones ) is this the best option and what other fuel components do i need?? i also am after a fiberglass rear lid on gas struds (2 cover the fuel system) is there any where in melbourne i can get one??
i think thats everything... really what im asking is there anything ive forgotten??? is what im looking at right? .. i dont wanna get half way into it and get stuck .. so come on guys noone will know better then u im after flat 11's so what do i need i only wanna do this once and do it right the first time ????
Posted on: 2003/11/28 3:55
SELF PROCLAIMED BOOST JUNKY
