coilovers
From Adelaide, SA the drift state
ok. i am putting in stanza struts into my 1200 ute. i am puting the maddat brake upgrade. i want to lower and stiffen the suspension. ive been told to use coilovers. looked through tech section and still doesnt make sense
cheers patts.
Posted on: 2006/9/24 11:20
Re: coilovers
have a look here these are a god deal
Posted on: 2006/9/24 11:50
Re: coilovers
not really keen on the weld on bit. has anyone got a pic of these on a car
Posted on: 2006/9/24 11:56
Re: coilovers
sssutes in SA, sure he could help out with the welding bit .... all coilover's are a weld on setup
Posted on: 2006/9/24 11:59
Re: coilovers
yeh my talents with a welder still a lil scratchy so yeh. were do i get springs form then
Posted on: 2006/9/24 12:04
Re: coilovers
From Sydney, Australia
king springs, or any spring place. They are a 'standard' diameter, as used in a lot of coilover kit.
Posted on: 2006/9/24 12:10
Re: coilovers
cheers fellas
Posted on: 2006/9/24 12:19
Re: coilovers
these are what sssutes are, pretty much all coilover kits will come out looking similar ...
these are a pedders setup i'm in the middle of (wouldn't advise this route unless you're prepared to do alot of messin about )
standard stanza strut body on the left, shortened coilover on the right ...
and these are a datrats set. all the datrats stuff is top notch as well
Posted on: 2006/9/24 12:25
Re: coilovers
yeh cheers its all making sense now. so stanza struts, with king springs on these coilover setup up seems alright for a ute runnin a CA turbs with street asperations only
Posted on: 2006/9/24 12:36
Re: coilovers
From Adelaide
Cheers guys for the plugs. Dat5 welding them on is very simple, if your interested i can do it for you, as im in adelaide too. Springs can be a bit of trial and era, but not to hard to get right. I have a CA18DET in a ute and im using 175 pound Kings with a free hight of about 225mm. Good ride hight(LOW), reasonably firm, Could be a bit stiffer for track use, but for road use great.
Scott
Posted on: 2006/9/24 13:09
