System won't charge.
Quite a regular
From Atlanta,Ga U.S.A.
Ok its been a long time since Ive been on here.
I have a datsun B210 1977 5 speed.
Charge light came on one day and wont go off.
System not charging.
Used several different batteries. Not Battery related.
Had alternator tested, GOOD, Replaced any how with re-manufactured unit. Probably not Alternator.
Replaced Voltage regulator unit.
Today went all ground connections, sanded and cleaned any corrosion i found, cleaned battery terminal and charged battery.
Re assemble, Still nothing.
I have a really high idle right now for another reason and still voltmeter at batt reads 12.40v at most.
I am Officially Stumped.
Any body have any similar experience?
Posted on: 2011/1/7 23:23
Re: System won't charge.
From Coondle, WA Australia
hmmm auto lect tricky.... sounds like a visit to an auto sparky might be in order.
Have you run your voltmeter at the alternator outpur to see if that is outputting the correct voltage?
The only advice i can suggest to methodically work along the wiring to try and find when the volts are stopping.
I dont evny you i hate when auto sparky stuff goes awry...
Posted on: 2011/1/7 23:40
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
