hyundai iload turbo?
From vic
hey i got a iload turbo for free i think its from a 2.5 diesel
would this be to big for a 1.2 a12? or should it be okay?
i just want to try it out blowthourh with stock carby and just a J pipe manifold
also the stock exhaust manifold what is it made from? can it be mig welded?
Thanks!
Posted on: 2013/4/8 8:42
Re: hyundai iload turbo?
From Adelaide
It's probably ball park the right size based purely on the power the iLoad makes 100-125kW. It might be a bit big but it's free so try it out.
The stock exhaust manifold is grey cast iron. You can google ways of welding it. You might get lucky with a mig doing it cold. There are two ways that should work:
1: heat the manifold slowly and uniformly till it's a dull red, weld, then post heat it to keep the temperature uniform and cooling slow. I've read about people burying them in sand to slow the cooling.
2: weld it cold with nickel rods (I've not come across any nickel wire for a mig)
I reckon the easiest way would be to keep the flange off the pipe side and weld onto that.
Posted on: 2013/4/8 10:58
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From vic
alright cool sounds good
Thanks!
Posted on: 2013/4/8 11:45
