WTB- H165 axle/s
From Melbourne, Aus.
I require an axle/s for a H165 23 spline out of a ute diff housing.
The shaft is Approx 580mm from the backing plate to the end of the shaft.
One will do but would like a spare.
Or alternatively if you happen to have a stronger diff laying around that would bolt straight in :)
I'm in Mitcham VIC, Local would be best.
Thanks.
Posted on: 2014/6/19 4:03
Re: WTB- H165 axle/s
From sydney australia
Pity Im up in Sydney, cause I've got a H190 520 ute diff housing, axles & centre that have been sitting around for years that I think had the spring perches narrowed to suit a 1200, the axle tubes baffled & the filler plug raised, the alloy centred 4.6:1 diff had been welded up, about the only thing left to do was to get the axles redrilled to 4 stud & the back brakes replaced with some stanza or such backing plates. Would probably be what you're after. Maybe somebody down in Melb has something similar. I assume the car broke an axle, rather than the centre. Grahams wreckers here in Sydney seem to have a collection of 1200 utes, maybe they can help get you rolling. They advertise on Ebay as http://www.ebay.com.au/itm/DATSUN-120 ... ories&hash=item3390720929
Posted on: 2014/6/19 11:22
