Re: whats a good diff to use in a 1200??
Posted on: 2004/1/21 7:01
From wodonga, victoria
it depends what sort of power you are going put infront of it. the ute diff is very good another good choice is the sunny diff, but you will need to make mounts.
so tell us what sort of power you are going to have and then a better decision can be made.
Posted on: 2004/1/21 5:49
A. If you have a ute, then the original H165 is a popular choice for good reason.
B. If you have a Coupe, a Wagon or Van with leaf spring suspension, then refer to "A" for a straight out, bolt in, rear axle assembly conversion.
C. If you have any other body type, refer to "A" for a slightly more difficult conversion due to the weird rear suspension.
Check the rear axle section of this site for more info.
Chris
Posted on: 2004/1/20 14:22
Love your Datsun.
Treat it well.
From Adelaide
hey just wondering what good diff's there are out there that'll fit a stock 1200. lsd or not.
cheers fellas
Dwayne.
Posted on: 2004/1/20 14:13
