that clutch
From Australia, NSW near Tamworth
if you do the job yourself...lightly sandpaper the flywheeel to take off the glaze, if you don't have a spare spigot shaft wrap take around some dowelling but only loosely tighten the presseue plate. Then you slip in the gearbox to align everything, jiggle slightly then gently pull out the box, tighten pressure plate and replace the gearbox..it worked for me!!
Posted on: 2004/4/3 14:52
