Re: brake booster on datto ute
From Maryborough, QLD, OZ
i have a 120y booster waiting to go into my ute....so if anyone knows if they are a straight fit...(no mods neccessary) that would be great!!
But from what i can see, there is a fold in the metal of the fire wall right where the spacer for the booster has to go......mine is an '84 model....were older ones any different?
Posted on: 2004/4/24 23:42
From Toowoomba QLD
will the 120y booster and master sit in the ute as standard?? (ie just unbolt from 120y and bolt into 1200 ute). And is it really necessary??
I just removed the struts from 120y to put into my ute so I can have discs but was told with the 11/16" master cylinder that I dont need to run the booster. True or False??????
Posted on: 2004/4/23 7:22
From Melbourne,Australia
Hey mate 120y booster bolts straight on then use a 240k master and you shold have no problems
Posted on: 2004/4/23 3:02
From yeppoon qld
thanx dude
Posted on: 2004/4/22 13:58
From Sydney, Australia
If you put the word "booster" in the "Search" section to the left....you'll have enough reading to last you a few hours.
Posted on: 2004/4/22 10:10
From yeppoon qld
ijust put in stanza struts and been trying to find out what the best booster and easiest to install behind the master cylinder.will a 120y booster fit up alright.who has done this?
Posted on: 2004/4/22 9:51
