Re: retractable seat belts for coupe
From Melbourne, Australia
yeah, the one i still have on the driver side is setup like that, seems ideal, just wish i knew what it was off so i could replace the passenger one, guess i should check the part number out
Posted on: 2004/9/4 9:59
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Christchurch, New Zealand
I understand what you mean now. Can you mount the reel straight at the top therefore bypassing the belt going vertical to a point from the reel near the floor?
Posted on: 2004/9/2 12:20
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
um, i think you both are picturing something diffrent, the old ones i had mounted the "reel" up just under the rear window (behind the persons shoulder), id like to stick with that method rather than a reel down at the floor, as that would require an extra point to be added at the top
if that makes sense???, maybe a picture will help...stay tunned
Posted on: 2004/9/2 2:19
1200 Coupe Rallycar
From Perth Western Australia
In my ute i had a problem with the seats hitting into the return, as there isn't much room in that area. Is this the same with the coupes???
I was thinking about getting some that are mounted in the pillars, except i'd have to hack into the side of my car, no doubt weakening it. It would prevent people tripping on them in the coupes though.
Posted on: 2004/9/1 13:26
I bought new belts for my coupe last year and chose the non retractable due to them being cheaper and there were no hassles mounting them. The retractable units would also cause a space issue where passengers climbing in and out of the back seat would be tripped up by the units. However, in hindsight I would have chosen the retractables due to the issues my incompetent passengers have with adjusting fixed belts to fit them. Then my belts are left all tangled up and plain messy dammit.
Posted on: 2004/9/1 13:13
Rosso Corsa Red
14" Watanabes
i used to have em, but one jammed up (not sure what from)
what are people using?
i got some corrola ones i think, but they wouldnt work on the angle they need to be mounted on
Posted on: 2004/9/1 10:28
1200 Coupe Rallycar
