Re: steel rods
From Toowoomba, australia
they are cast rods as standard. i think i'll go with the standard rods and a good set of pistons and see wat happens THANX
DAVE
Posted on: 2004/9/9 8:07
why go up and down when you can go round and round
Re: steel rods
From Taupo New Zealand
I would be surprised if the stock L18 rods aren't up to the task. L-series are pretty tough motors. Aren't the stock rods steel anyway?
Posted on: 2004/9/9 7:54
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Re: steel rods
From Wellington New Zealand
Hey from memory, the L series rod in the competition manual is actually an FJ20 rod...
I doubt it'd be possible to break an L18 bottom end using FJ rods! (the heads might fall off the valves however....)
Posted on: 2004/9/9 2:38
Re: steel rods
probably no more than 1 bar or so. the turbo i have is rather large so i'm going to have to turn the engine quite hard what sort of revs are they capable of as i havn't had a great deal of experience with l series thanx
DAVE
Posted on: 2004/9/9 2:32
Re: steel rods
From Brisbane, Australia
L series bottom ends are reknowned for their strength. just prep the factory rods properly and they will cop alot of punishment. How crazy are you intending to go with boost?
Posted on: 2004/9/8 2:42
steel rods
hey all does anybody know a place where i can get steel rods for my turbo l18? or do ca18det rods fit thanx
DAVE
Posted on: 2004/9/8 1:22
