Re: Compression estimate?
From Little Rock, AR
There really isn't any way to estimate the compression on a setup like that without measurements/cc's/etc. The only way to get a so-so estimate is to do a compression check and see how it reads. Someone a long time ago posted a table that corresponded cylinder pressure to the engine's compression ratio.
Yes, flat top pistons will raise your compression quite nicely and much more than shaving the head or decking the block will get you. Stock pistons have a pretty deep dish to them, so flat tops would raise it quite a bit! Just make sure to size everything up if you're using a bigger camshaft than stock, you may need to cut valve reliefs in the pistons depending on how big the cam is, head gasket thicknkess, cylinder head shaved/block decked.
Bottom line, flat tops give higher compression which in turn creates more power and requires more expensive gas I've heard the A series respond extremely well to higher compression, but I never experimented with it.
Posted on: 2004/9/20 15:46
From Sydney
sorry to butt in but i think my pistons may be flat top or are extremely close to, what advantage/disadvantage does this have over the normal ones. im guessing more compression?
Posted on: 2004/9/20 14:38
Street Tail Dancers
1200 coupe - A14
From Brisbane, Narangba
Could someone give me a estimate on what my new engines compression will be.
-A14
-The block has been decked
-The head has been shaved flat
-The pistons are not like the deep dish ones that were original. They have a very shallow flat dish that is not the far off been flat top
Thanks
Posted on: 2004/9/20 9:39
