Re: Wheel Spacers - Need Advice Please
From sydney
I used those billet adaptors on my car when I wanted to use a set of wheels from a different make. They were great ,widened my track as a bonus and the car looked dead sexy.
Posted on: 2004/10/19 22:33
From Burbank, CA
yeah - those billet aluminum spacers cost $200-300 US!
use them only as a last resort.
Posted on: 2004/10/18 19:16
|||\ 81 KPB310 /|||
on the wheel stud upgrade bit ... chepest studs for the come straight from nissan.
can't remember which model, but one of the late 80's, early 90's skylines has real long bolts and used to be under $2.00 a bolt
Posted on: 2004/10/18 5:32
From Burbank, CA
I have those from another company. they are great...
Posted on: 2004/10/18 0:10
|||\ 81 KPB310 /|||
From Arlington, TX, USA
R-fastmotorsport wrote:
I have 28mm spacers but they are bolted on to your original studs and they have a set of offset studs to bolt your wheel to. Look great and 100% safe. Have pics if you want
Pic:
Posted on: 2004/10/17 22:39
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
ARP makes 2.5" studs rated at 190,000psi shear strength. I have installed these, with 25mm spacers, on 3 different cars, all with ZERO problems. And all of these cars were/are driven VERY HARD.
If you do it right, there's no problems. If you do it dodgy...
Posted on: 2004/10/17 22:36
From Sydney , NSW
Matty,
depends how thick as to how evil they may be ! I think 5mm may be okay with no mods, 10mm with your stud upgrade is probably okay too. I have 28mm spacers but they are bolted on to your original studs and they have a set of offset studs to bolt your wheel to. Look great and 100% safe. Have pics if you want and can sell you a set if they are what you need.
Cheers
Posted on: 2004/10/17 22:16
From brisbane
Is it ok to use wheel spacers if you have upgraded the wheel studs to longer and stronger ones or are they still evil?
Thanks Matty
Posted on: 2004/10/17 21:43
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
