Re: Engines
From sydney
i just did the CA18DET conversion on my ute and spent much more than 10K but i got alittle carried away.
It can be done for 10K with a front cut standard computer and so on and you will be happy with the power for awhile.
It should be able to run a high 13sec 1/4 in standard trim.
There is nuthing wrong with CAs they responed realy well to modifications so once you wallet recovers from the shock of the conversion cost you can get started on bigger and better things.
Cheers Luke
Posted on: 2005/2/2 6:56
Re: Engines
Not too shy to talk
What about a turbo'd CA18. Would that work out any cheaper? How quick would my ute go?
Posted on: 2005/2/2 6:44
Re: Engines
From WA
depending on where you take it - 10k should juuuuuuuust get you into a std ex-front-cut SR20DET with nissan computer.
remember, you'll need a brake upgrade, diff upgrade, fuel system and exhaust.
Posted on: 2005/2/2 0:56
Re: Engines
Not too shy to talk
I have roughly around 10k. And want someone else to do it. Do you recomend anyone?
I want it to go hard but not overboard if you no what i mean
Posted on: 2005/2/1 8:57
Re: Engines
From WA
yeah need things like
budget
what the car is for
power / ET expectations
big / small project
doing it yourself?
engineered?
etc etc
Posted on: 2005/2/1 8:32
Re: Engines
From Melbourne Vic
What do you want out of your car?? is cost more important or power or ease of fitment?? do you have a budget or a certain amount of power or quarter mile time you want to run??
Posted on: 2005/2/1 7:36
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Engines
Not too shy to talk
I'm after some info/advice on what enigne to put into my 1200 ute. What are the main differences in
-SR20
-CA18
(want it turbo'd aswell)
im open for any ideas.
thanks
Posted on: 2005/2/1 7:11
