Re: A14/A15 aftermarket cam ??
From Port Kennedy, Perth Western Australia
If it helps , the cam in my A14 has a 40/76 grind with 260 degrees duration and 220" lift.
She runs .040" oversize, worked A14 head, balanced bottom end , lightened and balanced flywheel and a single 48mm side draft.
Makes good power from 2000rpm .
Posted on: 2005/3/5 12:10
I think either crower or competition cams makes 2 for the a14/a15 already. It is in their catalog. Just go to their respective website and you can order one. I dont know how much they run but I do know they are streetable. let me know if you need more info.
Posted on: 2005/3/5 2:37
From Adelaide, South Australia
If you go to a good engine builder they should be abel to grind you up a custom one.
Posted on: 2005/3/4 16:33
From Dallas TX
I think I'm starting to figure it out now. I've found a couple of US places who have good experience with A series cams and offer several grinds, both for about $100. www.iskycams.com is one. This page is for the "DATSUN: 4 Cyl. 1300 cc (B-210) & LATE 1200 cc Pushrod Engine (A-12)". That shoudl also work for the A14/15 right? Which of those listed would be best for mild street performance (good drivability etc)? I'm guessing the one listed at the top based on the shorter duration and lower lift.
Posted on: 2005/2/24 2:57
From WA
mperdue wrote:
lalalalaaaaaaa i could go on forever but they're all available with google.
Please do go on. That's what these forums are for. And maybe you'll hit upon one in the US ;)
i think if you want some radical duration or absurd lift, then you need to get a new cam because the existing "meat" on the std cam won't allow for it.
if you want something mild like a 25/65, 25/68, 28/68 etc etc you can have the std cam reground because there is enough material left on the cam to still make it strong (not like the 1UZ ... regrind = broken cam lobes!) and the now difference in lobe diameter can be made up with a few adjustments.
that's my understanding of it anyways - open to correcton as always
Posted on: 2005/2/24 1:53
From Dallas TX
OH and thanks for the link Freak. Seeing that page will help me do a better search.
Michael
Posted on: 2005/2/23 14:53
From Dallas TX
Please do go on. That's what these forums are for. And maybe you'll hit upon one in the US ;) I did find the Crow Cams website before I posted this but the only thing I saw was a listing of Datsun OHC cams. Didn't know they had other applications. Sent an email inquiry but got nothin. But seriously if you know of other sources please post them here. I did search google for quite awhile actually and kept coming up empty. Maybe I jsut "suck at the internet". LOL
Also could someone explain difference between buying an aftermarket with a particular grind and with just having the stock cam ground? If you end up with the same thing then why doens't everyone just grind the stock cam? Sorry if these are dumb questions but I'm just learning here. THanks -
Michael
Posted on: 2005/2/23 14:49
On the subject of cams what is the feedback people have heard of Waggot cams?? This is who did my cam and it seems quite nice and the shop recomended them to me aswell....
Dave
Posted on: 2005/2/23 10:04
From WA
crow cams australia
tighe cams australia
kent cams
Posted on: 2005/2/23 6:56
From Brisbane, Narangba
Over here in Australia we have quite a few businesses that grind cams. They have many common cams like 25/65, 35/70 etc to suit almost any engine and you can also get custom grinds to suit your specific application. Im sure in america there would have to be places that could do this.
This is australian but have a look what I mean http://tighecams.com.au/cars.htm
Posted on: 2005/2/23 6:17
