Browsing this Thread:
Re: new cam troubles
I agree that maybe what ever was used to hold the followers in is doing a good job.
Did you tap them into the block to hold them? If so you may need to give the adjuster side of the rocker a light tap to free them up.
And I don't want to insult your intelligence, but did you put the pushrods in the right way up? (Ball to the bottom, cup to the top.)
Posted on: 2005/3/31 9:50
From Warburton vic
If it was inccorect cam timing the push rod length shouldnt matter.
Posted on: 2005/3/31 7:55
From Brisbane, Australia
can't be that - he's complaining that something is binding when installing the rocker assembly, preventing it from meeting the cyl head. If the cam followers were missing, the pushrods (even the long A14/15 ones) wouldn't be anywhere near the rockers - even the ones on a cam lobe at peak lift!
from the info we have to go on at the moment, most likely causes in order are:
1) incorrect A14/15 pushrods. PLEASE measure one! it will take about 3 minutes to eliminate this possibility.
2) incorrect cam timing.
there is another possibility too - maybe whatever he used to hold the cam followers in place when installing the cam is doing too good a job of it
Posted on: 2005/3/31 7:37
From durban, south africa
make sure you CAM followers are now not sitting in the sump, if you never took the engine out...........
here's my two cents, i agree with benny. if you pulled the cam inplace the cam followers are lying in your sump and the pushrods are sitting on the camshaft, thats why you cant adjust them.
in fact i place money that they are in the sump
Posted on: 2005/3/31 7:18
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
sorry double post....
Posted on: 2005/3/31 7:17
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
are you sure the cam timing is correct? I see you've posted another thread asking how to setup the cam timing
http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=15955&forum=1
what do you mean IF its a billet cam? Only you would know! Did you supply them a cam to regrind, or did you purchase a cam from billet off them?
humor me and answer the questions I've asked you for once. Can't help if you don't give us more info - we're going around in circles at the moment.
Posted on: 2005/3/31 7:08
From ipswich
cam timing is correct and stil having troubles, when tightend there is still a gap and there is an extreme angle on the rockeres that are opening up the valves. if the cam is a billet cam would this be happining???
Posted on: 2005/3/31 5:32
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
From Sydney
Posted on: 2005/3/31 4:15
From ipswich
i know that the push rods are a12 ones as i tried to fit a14 ones when changing the head and the where to long and i still had a spare a12 pushrod laying around and i measured it up to the new ones and it was the same lenght
when i tightened the rockers i reset the crank to t.d.c to do the cam timing so maybe it was the valves opening up againts the pistons
and by the way who ever said that you cant put a camshaft in while the engine is still in the engine bay is wrong it was easier than having to take the engine out
Posted on: 2005/3/31 2:05
datsun 1200 ute
OK, just went downstairs to measure this stuff. These are eyeball figures of the pushrods measured from outer extremities:
A12 151mm
A14/15 166.5mm
Posted on: 2005/3/30 13:38
