Re: LOOK OUT! my drums suck
From California
The words "will bolt right in" & "identical" rarely end up being the case.
Be sure to let us know how you made it work.
BTW, how do the tracks compare?
Posted on: 2005/4/5 18:37
Hello,
I am in the middle of doing this swap. The rear from a 1979-1980 200sx will bolt right on. They have the solid rear axle setup with disc brakes. I just pulled (yesterday) the rear from a 1979 200sx with disc brakes and it is identical to the rear in my 1979 210. I will install it this weekend.
Once again it is a perfect swap. Good luck.
Posted on: 2005/4/5 17:19
Not too shy to talk
From Narre Warren Vic
OOps' hit the quote key by mistake
Posted on: 2005/4/5 12:34
Not too shy to talk
Cool dodgeman.I actualy thought the WA in his profile was western Aus.Anyhoo playing with rear disc setups is a lot of fun and definately not a step backwards so I say go for it unless the rules you're gunna race under say you cant.I belive the toyota corona RT141 rear brakes are nearly identical to the Bluebird ones I mentioned and I'm prety sure they were available in the US,but there are many ways to skin a cat(the important thing is to skin as many as possible)
JoeQuote:
Rallytwit wrote:
General as someone with 19 years of road racing under my belt take this advice: Do not get hung up on a particular car type or feature such as disk rears. If you are looking to be competitvie the thing to do if you haven't, is go to your local track and see what cars are competitive and buy one already prepped.
It is much , much cheaper to buy a prepped car than to build one.
With that said if you're a Datsun / Nissan die hard and just want to have a bit of fun then great find a prepped 200SX and have fun with it.
I don't know what your racing experiance has been but even at local SCCA club races there will be some really good drivers and you will not likely be competitive at first. So get yourself a cheap reliable starter car that you can easily afford. You will find the serious club racer spending $750 to $1000 on a low tech ITB VW Golf. Even a cheap arse like me who runs a dog slow car just to have fun , is spending $400 a weekend.
Back to your original concern on disc rear brakes , contrary to popular belief going fast on a road course does not consist of roaring up to a corner and standing the car on it's nose. Trail braking is how you keep your momentum and that just requires keeping the brakes cool.
The only racers I know who have had problems with drum rear brakes are the Improved Touring RX2/3 and early RX7 guys and that's becuase the engines were making 60 HP more with the class not allowing brake upgrades.
Tom
Posted on: 2005/4/5 12:31
From Las Vegas USA
Tom
Posted on: 2005/4/4 19:39
Not too shy to talk
From Grapeview, WA.
Im into road racing. Not to extreme... Im just getting into it. The year I am thinking of is 85-87. My parts dealer informed me that those years came with read disks.
What front disks can i use?
Posted on: 2005/4/4 17:48
From Canberra, Australia
200sx in australia is different to 200sx in america...
What year were you thinking of?
Think you would be better off with bigger front brakes though.
Posted on: 2005/4/4 17:33
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Drum brakes on the rear have a lot to offer & any car with really good front brakes doesn't really need more, after all, it's hard to improve braking performance any more when the rears are in the air.
OK, enough silliness. When the fronts are really doing their job, the contribution made by the rear brakes is realatively small,... small enough for most drum brake setups to handle without much drama.
Are you into big time racing, or is this a street car, & what symptoms are you experiencing that makes you want to do this conversion.
Joeninety
The Bluebird that you refer to is diferent from the same model of car that was sold in other markets. I don't even know if a version of the 910 [Blurbird] was even offered in the US & i believe that the brakes that you refer to are Australian made Girlocks. I don't know if these were sold outside Australia either.
Perhaps you could add some location details to your profile too.
Posted on: 2005/4/4 13:27
Love your Datsun.
Treat it well.
Not too shy to talk
210/310 are not IRS like the 200sx so it would be a tricky conversion, but not imposible.Bluebird disc over drum rears are a piece of piss to fit to many rear ends. If they dont bolt straight up they wont take much modding to fit (re-drill).Handbrake cable is the same style buy may need shortening.You may need a bias valve as well,unless you like a bit of rear bias.
Posted on: 2005/4/4 12:31
Not too shy to talk
From Grapeview, WA.
Well I think that I am going to have to find a 200sx. I was just hopin that someone might have done this mod already. As far as i could tell 85-87 200sx had disk brakes. Or atleast thats what I have been told from my auto parts store. Ill do some digin.
Posted on: 2005/4/4 6:46
