Re: any suggestions or opinions please?
From Brisbane
Ok thanks heaps aye.... ill need 2 see wat i can find....
thanks
maztec
Posted on: 2005/5/26 15:32
From Christchurch, New Zealand
1/ The head will have to be found at a wreckers etc and this should not be too hard. Unsure of costs but it is a simple bolt on for your Sunny A12. The flow this head will create is good for the following modifications too.
2/ Extractors are often for sale and can range from $50 right up to $250 new ones (not counting the expensive Nismo ones). They are a bolt on in place of your manifold and a bit of welding down below to connect to the exhaust.
3/ Now this is the most expensive part. If Steve is talking about twin Webers as I guess, then I know in NZ they are around $400-500 second hand and people in Australia have recently noted around $800 for a decent pair. This may be a little high though so you will have to find an average price in your locality.
A new inlet manifold will have to be sourced and these range from about $100 second hand and somewhere in the $200 region for new items. A linkage kit is also required as well as filters and jets etc. Search the forums for photos and information.
It can be heavily subsidised though by finding a setup already complete for sale.
The last alternative could be to install an A14/15 as the power increase alone is the cheapest upgrade.
Hope this helps as a starting guide.
Posted on: 2005/5/26 13:11
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
From Brisbane
ahh ok thanks... do u kno approx. costs??? and if it will be easy to fit and mod???
thanks heaps for the advice 2 :D
Posted on: 2005/5/26 12:55
Try and get the A14/15 H89 head which has high compression (heart-shaped) combustion chambers and oval intake ports.
Posted on: 2005/5/26 12:53
Rosso Corsa Red
14" Watanabes
From Melbourne, Australia
get a a14 head and webers whith extractors and it will go good
Posted on: 2005/5/26 11:49
When the going gets tough the Datsun keeps going😋
From Brisbane
ok i kno this is a very vague question....
i got a datsun sunny gl 1981 model wif a stock A12 in it. i wanna get some power out of it without spending too much money on it...... so i was jus wunderin wat thing i shud do (eg... webers, extractors, carbie etc..) to get this thing woopin sum VL a$$???
any help is appreciated..
thanks
maz
Posted on: 2005/5/26 11:39
