crap put it in the classifieds, can the mod move it to general discussion please? sorry wasnt thinking
ok i go a sr20de in a 1200 ute on custom mounts etc...
im trying to get the box and motor out whether it
be in 1 piece or 2 or 3 or 4 and so on, basically i
have removed all wiring and hoses and
radiator,tailshaft, all steering linkage and all the front end is off the crossmember so its free standing so i can drop the crossmember.
all in hope to get the box and motor out in one
then looks i cant coz of clearance, i cant drop the
motor and box as one, coz the manifolds will hit
( take off inlet manidold and exhaust then and try n drop it?)
cant drop it front crank pulley hits the radiator
support ( can i cut that out a lil only need 15mm of
clearance and weld a new removable bit bak ?)
or take off crank pulley ( how u do that?)
cant get to starter motor without taking the inlet
manifold off( more friggen work) ?
Cant drop in one piece motor to wide ( manifolds
hit and crank pulley)
cant push forward crank pulley hits radiator
support)
cant lift up with box still on, head hits firewall
ne1 u no taken a sr out of a 1200?
ne other methods of removal, i dont care how it
gets out just need the box and motor out, dont
care in how many pieces ( intact tho no explosives
haha)
pic1
YELLOW is the pully hitting the radiator support
RED is what im thinking about cutting out :P and
putting a removable plate in there bolted onto the
support.
pic2
RED: intake manifold and ( plenum i think its called)
YELLOW: the rough line of the chassis rails, nething
to the left need to not be there for the motor to
drop
GREEN: rough location of starter motor under the intake
pic3
YELLOW: where i took the suspenson thing off to
free it from the crossmember, and also removed all
steering linkage
pic4
just a pic to show how LITTLE room between back
of motor and firewall, its about an inch :P
pic5
pic of gearbox crossmember
YELLOW, location of bolts holding it to the floor( is
this a good location for it to be fitted? i heard of
ca18det's needing to connect to chassis rails?
