Re: L28B into sunny?
From sydney australia
yes,i used redrilled stanza mounts,dropped the engine about 10 mm.i should have got the motor moved back about 5 mm as well,as the swaybar is rubbing on the front of the sump.i'll try fitting a stanza swaybar,but i'll probably get
another set of mounts redrilled anyway.my problem was i've got an l18,& the standard l series oil filter hit on the engine mount,so i got a stock a series oil filter,& it gave me enough clearance for the filter.
Posted on: 2005/8/8 2:34
From Central Vic
Not into square headlight model
if you redrill the mounts that bolt to the block and choose the right engine mounts the rockercover just rubs as i said just
Posted on: 2005/8/7 10:46
From South Dakota USA/Trinidad and Tobago
you guys may not believe me when i tell u this but i actually saw with my own 2 eyes an L28 in a b210 120y.ofcourse he did have 2 cut the firewall etc and let me tell u that car is one of the fastest 120y i've ever seen.i wish i had some pix to show y'all.so may an l28 should fit in a sunny with some cutting and all,but thats too much trouble anyways
Posted on: 2005/8/3 18:29
From Victoria, Australia.
with a stanza cross member a L20 will just fit
Not into the Square headlight model Sunny because of the tapering bonnet. The L20 is too high.
I still had to cut some webbing out of my bonnet just to clear the L18...
Posted on: 2005/8/3 16:49
From Central Vic
Posted on: 2005/8/3 12:22
From Brisbane
haha yea i thought so... ill jus stick to gettin an A14 in my sunny.... :P well thanks for the advice
maztec
Posted on: 2005/8/2 12:58
haha yeah not worth the hassle. but imagine a rb26dett powered datto!!! *drools*
Well go fit a RB into a Zed or early Skyline.
Then you'll have your RB26DETT powered Datto...
Posted on: 2005/8/1 21:39
From Christchurch, New Zealand
Posted on: 2005/8/1 13:53
well,seeing as a l18 or l20b fills the engine bay, so with an l28,you'd have to mount the radiator on the front of the grille.you could make it fit if you were prepared to cut the firewall & refabricate the firewall & transmission tunnel.by the time you'd got a transmission on the back,you'd have to get the rear passenger to change gears for you.the point of all this frivolity is,no it won't fit without cutting the car.
Posted on: 2005/8/1 13:44
ive been thinking bout straight six swaps lately, if the six pokes out to where the radiator would be, theres some radiators out there e.g ford sierra ones that will fit in front of the car behind the grill and bumper nicely, they have a external fill bottle thingy that u can locate wherever u want
Posted on: 2005/8/1 13:09
