Re: heads
which one would u use on a daily driver with a good punch to it?
For best punch below ~3000 rpm, go with the round-port heads. For punch above 3000, go with the oval port head.
The closed chamber is good for maybe 3% extra power (if you use the 10% more expensive 'premium' fuel), and it helps increase both low and high speed power. Somewhere around here is an analysis of the compression ratio difference.
Guess: the oval port head will give more high-speed power than the closed-chamber round port head.
Posted on: 2005/10/17 5:32
heads
From Alabama, U.S.A.
o.k. I have read all the info in the tech section on the A-14 heads , I have three diff. heads here --- oval port open chamber, round port open chamber, & round port closed chamber , which one would u use on a daily driver with a good punch to it? give me all your opinions.--- also going to use the higher compression stock pistons of the two A-14's
Posted on: 2005/10/16 23:58
