Re: 1978 datsunb 210 engine mods?
From SE Melbourne
What differences did you find between the A15 & A14? - especially on the race track?
Posted on: 2005/10/25 7:16
Mildman, Datsunless
From Warburton vic
Theres no substitute for cubes. The a15 will produce more torque than the a14. I had a stock A15 in my 1200 before i went to the A14. The A15 had twin 40mm webers & that went pretty good. But would only rev to about 6500rpm. the only reason i went to the A14 was because i had one on the engine stand being built wich i run on the race track. I would run whatever you can get.
Posted on: 2005/10/25 1:14
From SE Melbourne
In stock form though the A14 and A15 have almost the same quote horsepower, which I assume is because the A14 can rev higher (otherwise it wouldn't have the some hp as an A15)
I see what your saying about "no replacement for displacement" but hp=torque x rpm...so both torque and rpm are important to a circuit car engine.
Does anyone have a torque + hp curve versus RPM for both the A14 and A15, that will show us all the characterisitcs of both motors.
Posted on: 2005/10/25 0:32
Mildman, Datsunless
From sacramento california
ok so what about using nitrous on a webber powered a14?i am going to do it regardless of what i hear but im going to make my own spray kit like a fogger into the air filter assemboly.how well wil lthis work?
Posted on: 2005/10/25 0:06
From Invercargill, New Zealand
A relatively stock A14 is not a rev meister
That hasn't been my experience Mat. My stock A14 would hit 7000 rpms more quickly than any of my stock A12's could. It was in a N10 Pulsar so perhaps the lighter flywheel helped but the A14 is well regarded for it's revability.
Posted on: 2005/10/24 21:46
From California
Mildman wrote:
Brings me to an interesting question Mat
As I recently discovered an engine I purchased which I thought was an A15 turned out to be an A14, so far all it has cost me is the respect of my "datto expert mechanic mate".
From my understanding of the difference between the two engines the A15 is just a stroked A14...which should mean that the A15 will have more torque produced at low RPM, but will not manage to reach as high an RPM as the A14 - due to this longer stroke....
I'm think this means that an A14 will rev harder and thus produce good hp at the top of its rev range...sort of balancing it with the A15.
I'd like to see a dyno print out of an A14 and A15 side by side to really see the torque behaviour.
Has anyone studied this in much depth before?
We're talking normally aspirated here, so unless you're spending serious $$$, go with the A15. The difference is in the longer rods which equals increased stroke or displacement. Ideally, you want to oversize pistons if you've got the budget. A relatively stock A14 is not a rev meister, so you'd be wise to go for the cc's. Likewise, if you want a torque monster, go for a ka24, and don't waste your time with an A15.
Oh, and for the Americans here, make sure you use the A14 GX head and NOT the A15 head. And you'll need a cam regrind since both the A14 and the A15 U.S. spec cams are designed for fuel economy and nothing more.
Posted on: 2005/10/24 20:12
From Burbank, CA
If you can get the right weber adaptor then that's good, I could never get one that went to my manifold. I ended up making one.
I like the weber it goes better and it lots more fun. You'll probably find it to be less reliable than the oem carb. Maybe with enough tuning and messing around it can be as reliable as that stock carb.
Reliable?
It's hardly ever done anything so bad I couldn't fix it or left me stranded.
Get a very good filter for the fuel, webers seem to get plugged up with very tiny stuff that the oem carb didn't mind.
I love my weber and A15. With the right setup I think it's lots of fun.
there are alot of variables, between a14 and a15, there are an assortment of heads, with different shaped ports and combustion chambers.
I think it's probably reasonable that the a14 might have a Hp spike above where the a15 levels off, the a15 will have more torque up to where the torque / HP crosssover point where the A14 will make a little more HP, but the A15 having made more torque off the line would be faster.
someone would have to have an a14 block and an a15 block and swap the head and intake and exhaust to really answer which is better
some people really like the a12 it's got a really short stroke and revs even higher and makes more hp than the a15 in some cases
Posted on: 2005/10/24 19:22
|||\ 81 KPB310 /|||
From SE Melbourne
Posted on: 2005/10/24 15:29
Mildman, Datsunless
From California
I bet the dgv helps, but you'll probably want to find a spare A15 and build it up if you want your B210 to fly.
Posted on: 2005/10/24 3:58
i livebin albany oregon your in bend?how much did you end up paying for your swap. and what else can i do other than carbs?
Posted on: 2005/10/24 1:26
