Re: Brake upgrade info required
From Taupo New Zealand
I'm not 100% about the Aussie 120Ys as they were different from the NZ ones (except the coupes possibly?) but the sunny has bigger stub axles than a 1200, they are the same size as a 1600. Not 100% sure but I think the 120Ys changed from the smaller size to the larger size part way through their production run???
Posted on: 2005/11/11 22:36
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Stray-ya
I dont think so Freak. I am assuming that the PBR 120Y are the alloy calipers not the steel plate ones, but either way (I have one of each at home) the stub axle is the same size as the 1200. Not sure about the sunny- that might be what you want.
Posted on: 2005/11/11 10:33
From Brisbane, Narangba
Just a quick question for those in the know. Im currently running a 120y PBR brake setup on the 1200. If i dont have to I dont want to go to stanza struts as id like to keep the track the same as it is. Im sure ive seen on here that these brakes share the same hub size as the stanza, therefore allowing for stanza discs and the like to be bolted on. Is this true?
Basically i want to keep the same strut setup with larger discs and calipars if possible.
Cheers
Posted on: 2005/11/7 10:45
