Re: A15 extractors wanted
From campbelltown (sydney) australia
yep just like dattoman_1000 said, unless u are running sidedraught carbs then u will need different ones, if you are running stock manifold just cut the pollution gear off and it will clear.
Posted on: 2005/11/24 12:28
* caution, sunglasses must be worn to view my ca18det *
From Perth
They should be pretty much all the same
Maybe you need to relieve a little bit of alloy off the inlet manifold to make them fit
Posted on: 2005/11/24 11:50
Quite a regular
From Adeliade, Australia
Does anyone have extractors to suit an A15 motor? I have extractors from my a12 but they hit the inlet manifold on the a15 motor!
Posted on: 2005/11/23 21:52
