Re: WANTED - Standard 1200 Gearbox Crossmember.
From Canberra
the other bit is still bolted to the gearbox, you can have that too.
Posted on: 2006/3/7 8:28
From Tas
Check your messages Tyrie.
Posted on: 2006/3/7 7:59
From Canberra
I've got one with busted rubber you can have for the price of postage. I'm not sure if new rubbers are available? If not then its probably no use to ya.
Posted on: 2006/3/7 7:42
From Tas
Hi Nismo,
Shouldn't be that long before you see the ute running about. Just waiting on dash to get covered and a few more engine bits to arrive.
By the way still loookin for a gearbox crossmember and mount if anyone has one. I just haven't been on to check. Apologies.
Hi to B120dat if you read this..........loose the chrome
Posted on: 2006/3/7 2:59
From Launceston, Tasmania
Hi Buff.
What area of Launie are you in mate?
Have you seen my green 120y coupe or my white 120y coupe, both have superlite wheels on them.
I expect to see you attending some of our datto meets that we have.
So far we have had about 5 meets.
Our next one is under the overpass next to the old rundown CH. SMITH building at the end of Canal St.
See you soon.
Sorry don't have a 1200 crossmember for you.
GO THE DATTO!
Posted on: 2006/1/6 11:57
From Adelaide
i got one great cond. name ur price i pm u aswell
Posted on: 2006/1/6 10:56
From Tas
Hi Guys, its been a while......................
I'm after a standard gearbox crossmember with mount for my 1200 ute. Perhaps some of you guys that have done conversions may have one lying around no longer required???
Thanks if you've got one.
Posted on: 2006/1/2 22:13
