To correct what I said last year, there are two engines for USA in 1977:
- Regular, oval port A14
- Five-speed cars: Round port A14
Yours may be the 1977 round-port, or it may simply have had the head replaced at some time in the last 30 years.
The round-port is an excellent cylinder head for 4500 rpm or less operation. It got up to 50 mpg on highway with 5-speed.
See the pics for "A14 Round-port High-Swirl head" in the
Cylinder Heads. Note that this is not about the "swirl-port" head which came later, but is the "high swirl" head.Quote:
These have quench chambers (not open chambers) but instead of being used in high-compression engines, they are designed for high swirl (for better fuel economy and improved emissions). They are used with dished pistons. Unlike the swirl-port heads, these have unobstructed ports. The ports are lowered so that the charge is forced to swirl as it enters the chamber.
