Re: SR20DET into 1200 pics
Scott, the process of getting the coupe legal for the street is pretty hard and expensive, but possible. In western aust you can make pretty much anything legal if you do it by the book from
the beginning. Before i even started the conversion i had a consultaing engineer come out and inspect my car. He told me what i had to do to strengthen the chassis what brakes to use and
gave me a application for approval for the department of trans. I filled this in with all the details of my plans and recieved a letter back saying yeah it is ok as long as i get an
engineers cert. The car is almost finished now and the engineer will be coming back out soon to inspect it again. Hopefully it all goes well from here i cant wait to to drive the sucker.
p.s for intrest sakes there is a 200sx here with the same turbo as mine standard internals 15psi unichip that produces 320BHP (yes at the wheels!)
Josh
Posted on: 2001/1/18 8:48
From Sydney
Dont forget the steering box on the lhd. It would be in the way a bit for a 3" dump pipe! Josh, how are you going to get your 1200
legal with the SR20t?
Scott
Posted on: 2001/1/18 3:51
Dave, im usually online anywhere between 5:30pm to midnight my time which is 1:30am to 8am your time during the week but ill try and get on in the morning on the weekend and see if
i can catch you in the evening time your time. Lok forward to chating.
Josh
josh_clowes@hotmail.com
Posted on: 2001/1/18 3:03
Not too shy to talk
Hi Josh,
I'm using a T3/T04B hybrid. Should be good for 320 or so crank HP.
Chat - yeah! What times work for you? you're 16 hours ahead I think, right? midnight here is 4pm there. I'm in Oregon, USA so I'm
on Pacific Standard time.
Dave Lum
www.datsuns.com
Posted on: 2001/1/17 10:34
Hey Dave, the manifold looks great along with the rest of the conversion. My coupe is comming along nicely aswell. I will send some pics to you when i get the SR20DET back in for the
final time, you can then see the differences that there are between the Lh drive and RH drive conversions with the SR. My turbo sits right up, the exhaust housing is inline with the strut
tower, but i havent got a brake master cyl to worrie about on that side so it was a bit easier. What turbo are you using, ive chosen the killer turbonetics t-66
Josh
p.s should try and catch up and talk bout the conversions
Posted on: 2001/1/17 5:22
Re: How many seated?
From Sydney, Australia
After a friends 18th ...10 years ago, I squeezed 9 people (incl. me) in my 1200 station wagon. There were many problems associated
with such daring..
1. Drunk people are noisy..9 are deafening.
2. Retreaded tires tend to buckle under the load, and try to escape from the wheel rims. I was very lucky. It was like driving in
jelly.
3. Even when using the B210 disc front end, it doesn't stop very well.
I got everyone home safely...I was sober...I needed a drink when I got home...
Chris
Posted on: 2001/1/17 12:06
From Good Old Knockfull, Tennessee, USA
Excellent work on the exhaust pipes, Dave. A bit of advice, put a double aluminum heat shield around the master cylinder, it looks real close to the pipes. The fluid may take the
heat but I'm not sure about the seals in the cylinder. I would also suggest DOT 4 fluid but you probably use it anyway. It's going to be a honker. I want a ride in it. LOL
Posted on: 2001/1/16 5:39
I had fit a total of 6 people in my 1200 before -- me driving and a guy with a girl on his lap in the front, and three in the backseat, I had to go SLOW over speed bumps as my car is already
lowered. I've sat in the backseat of 1200's before, and even though it is somewhat cramped, it wasn't actually all that bad! I've sat in the back of all of my other friend's cars, and they
are absolutely HORRIBLE compared to the 1200! My friend's 1993 Mazda MX-3 forces you to bend your neck sidewaysif you are over 5 ft tall and it makes you sit straight up because the back
part is not countoured at all. My other friend has a brand new Ford Mustang and even with the seat all the way forward you still have NO leg room whatsoever, and your head will also hit the
roof. His Mustang actually has less legroom than the Mazda. My brother has an older Mustang (1990) that isn't too bad, comparable to the 1200. My other brother on the opposite end of the
spectrum, had a 1968 Buick Riviera and it had the most comfortable rear seats, plenty of legroom, and room for up to four pretty comfortably in the backseat. All in all, the 1200 has a good
backseat in my opinion. Did you know that you can fit the bottom seat portion from a B210 into the 1200? It's a tight fit, but it goes right in with no modifications, and it's much more
comfortable on the rearend. I did that on my other 1200 and the passengers were quite appreciative.
-Andy
Posted on: 2001/1/16 4:18
Not too shy to talk
Guys,
The manifold for my SR20DET is done. Check out the latest pictures
http://www.datsuns.com/projects/1200/ ... ct_1200_latest_picsII.htm
Also, www.datsuns.com got redesigned - check it out and send me feedback!
Dave Lum
'72 1200 getting clower to SR20DET power
'71 1600
'00 Maxima
www.datsuns.com
Posted on: 2001/1/16 9:13
Re: how many seated
From Sydney
Theres only 4 seatbelts. Legally only 4 can be in there not 5. 5 is a sqeeze tho!! I have however managed to fit 7 in my old coupe!! I was glad to be driving but if i got pulled
over it wouldnt have been as funny!! Now my new coupe has no back seat. In fact, its only got the drivers seat at the moment! Its still off the road, the head has gone in for a
freshen up.
Scott
Davo
Posted on: 2001/1/16 3:20
