Re: before and after
From Melbourne, Victoria
just an update photo
lots of new little parts, should be going this weekend after i do the hydrolic clutch conversion and get the fuel regulator on
Posted on: 2006/5/11 0:55
evan, just put some filter socks on it an you dont have to touch anything....
Posted on: 2006/4/20 23:36
nuh fella a weber 45 DCOE side draft 2 barrel.
and in your hunt to learn on carbys,
click me
Posted on: 2006/4/20 14:40
From Melbourne AUS
ahhhh ok.. thought it was an ida... or is it?
havent had much experience with webber's
or carbs in general...
but im about to...
looking foreward to seeing yours up and going... keep it up
Posted on: 2006/4/20 14:29
1973 B110 A12
yeah already looked into that, but because its a sidedraught weber i cant mount it like a downdraught, but thats ok. ive got no problem doing the extra mods. ive already organised the remote oil filter and k&n air filter. just need to cut and paste the filler.
edit: haha nice try
Posted on: 2006/4/20 14:25
From Melbourne AUS
hmmm you have to mod the oil filler also??
seems like a bit of work to mount the carb that way...
why not ditch the upper manifold and mount it upright?
edit: or better still ive got a perfect nikki carb that'll fit just fine complete with standard and ramflo filters that ill do u a deal on for the webber
Posted on: 2006/4/20 14:21
1973 B110 A12
Posted on: 2006/4/20 14:19
nuh it will fit fine without a filter, but id rather not suck up bugs, rocks and small children into the weber so im gonna fit a filter. but to do that defaintly have to go the remote oil filter.
Posted on: 2006/4/20 14:17
From Melbourne AUS
is the remote oil filter to accomodate the webber also?
Posted on: 2006/4/20 14:11
1973 B110 A12
hey ange yeah im getting right back into me ute. broke up with the mrs not long ago so i have money to spend on it again cant believe how expensive women are. should be on the road soon, couple things to do
*Things to do*
- get correct lower manifold made for weber
- hydrolic clutch set-up
- new carpet for interior
- remote oil filter
- air filter for weber
- cut and weld oil filler tube so filter can fit
- exhaust changed (way to loud at the moment, well over 120db)
- find new cheap girlfriend to have sex with
- couple other small things in engine bay (hoses etc.)
then we go cruising
Posted on: 2006/4/20 14:08
