Re: power
From Vic Bendigo
well i got a j13 that is bored with along strock a 5 speed supera box and down draft carbie i think its bored out to 1419cc from 1399cc i think
Posted on: 2006/4/28 11:16
Re: power
From Alabama, U.S.A.
More bottom end , I think you need to up the comp. & use the right header design would help too, like a 4 into 2 into 1 with long primaries .
Posted on: 2006/4/28 2:55
Re: power
From Townsville, Qld
I paid 100 bucks for 2 vanettes containing A15s, now I'm down to my last engine and gearbox. It's great that some people dont understand the value of things they're selling
Posted on: 2006/4/27 12:05
Re: power
From Vic Bendigo
i like the thought of doin a engine trasplant but what is a a15 werth (stock) exhaust the hole lot what is it worth or what hav u guys paid 4 urs
Posted on: 2006/4/27 10:45
Re: power
The best way to get low end power for your car with a normally aspirated A series engine [which isn't really what you asked for] is to use an A15 engine. These use a 3mm larger bore,which isn't the important part, but they use a 12mm longer stroke, & this is the real secret to it all.
That's a half inch stroker over your A12 engine & that translates into torque, which is what low end power is all about.
Even a stock A15 will out-torque a mildly modified A12 at lower speeds. The upside to switching engines is that the A15 comes with the bigger port & bigger valve head to begin with, so there is more scope for improvement once you grow tired of a stock A15's performance.
Even the A14 with its 7mm increase in stroke will offer a very usefull improvement along with the better cylinder head.
Have a think about it & do the maths before spending any money.
Posted on: 2006/4/26 21:09
Love your Datsun.
Treat it well.
Re: power
From Burbank, CA
if you want low end torque, resist the urge to get a big exhaust system, too large a pipe and you loose low end and gain top end power.
Posted on: 2006/4/26 16:17
|||\ 81 KPB310 /|||
Re: power
From Vic Bendigo
yeh i want low end power i was thinkin of putin j13 pistons in it because there flat top would that make a differance, and sorry if the question was a bit hard to under stand
Posted on: 2006/4/26 12:41
Re: power
From Bendigo, Victoria, Australia.
so....... u want low end power? its a bit hard to get that from an A12 (or any A series) but the best way to do it would be getting header pipes and a good exhaust system. upgrading the carbie and tuning it will be important if you want to get maximum low end power.
also a low ratio diff would help (the H165 from a ute had 4.11:1)
i hope i read ur post right.
Posted on: 2006/4/26 12:39
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
power
From Vic Bendigo
what is the best way to get power out of a a12 without puting a turbo on it low end power
Posted on: 2006/4/26 12:34
