Re: sr20 5-6speed?
From Brissy
The sr20det 6 speed is weaker than the 5 speed as well... 1-3 gears inside the box are a little thinner than the 5 speed to make room for the 6th gear... a lot of the s15 guys blow second gear and then replace them with the s13/s14 5 speed...
what i would like to know is what 4 speed gearbox u r changing from...
do u have an auto behind that sr???? how does it go?? the auto would be very cruisy in a 1200... and only a little bit slower...
Posted on: 2006/5/5 1:53
Re: sr20 5-6speed?
From Sydney, Australia
Auto tunnel to begin with, and cut top side of tunnel at shifter and welded a box section onto the tunnel.
Not too hard, requires 1.5 inch cut into the double panel in line with the front seat support rail. Moving of handbrake back 2 inches.
Got photos:
Photo inside car
View down tunnel
View of Gearbox Mount
Posted on: 2006/5/4 19:24
Re: sr20 5-6speed?
Seems like 5 speeds the way to go! neways 5 will be luxury anyway, wasnt complaining when i only had 4! how did u go fitting the 5 speed into ur datsun (dattodude)???
Thanxs Phil
Posted on: 2006/5/4 18:58
Re: sr20 5-6speed?
From Newscastle, Australia
ILooked into this too. There are heaps around sydney for about $1000. Trouble is that they are much weaker than an SR20 5 spd, and it would require lots of tunnel mods. Pure wank factor only...and i know no respectable club memeber would go for that.
Posted on: 2006/5/1 23:03
Dont die wondering.....
Re: sr20 5-6speed?
I guess W.A means west africa?
I assume Western Australia. Ring up an importer or get on some Silvia forums and get one, there are plenty available from Perth or Sydney or Melbourne, or Adelaide.
The 6 speed is a lot bigger. Would require more mods to tunnel.
Cheers,
Chris
Posted on: 2006/5/1 20:53
sr20 5-6speed?
Just wondering if anyone knows where i can get a manual gearbox??? living in W.A. having a bit of a hard time chasing 1 up! any comments welcome!
Posted on: 2006/5/1 17:48
