Re: CA BOX
From sutho shire, NSW, AUS
thanks lads
im definatly not too keen to put a new box in at the moment hey and shes prefectly drivable. thanks.
Elliott
Posted on: 2006/5/4 3:20
Re: CA BOX
From SE Melbourne
Or just start practicing changing into second gear without the clutch at all.
As long as the revs are right it should just pop straight in.
Posted on: 2006/5/4 2:29
Mildman, Datsunless
Re: CA BOX
From Brissy
i kept driving on mine till i melted the 2nd gear syncro's together on my last ca box.....
personlly id keep on going till she blows.....
as lagwagon said setup ur clutch travel and that may help a bit...
Posted on: 2006/5/4 1:45
Re: CA BOX
From Melbourne Vic
yeah, the second gear crunch is common, mine seemed fine intil you tried to change at high revs, i have a mate whose was a bit worse than mine, second gear aswell.
check you have the clutch disengaging enough when you push the pedal, i know i had to muck around with mine a bit to get it right...
my advice, ignore it!
Posted on: 2006/5/4 1:27
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: CA BOX
Not too shy to talk
From sydney
my mate has a skyline GTR and they reckon its common in them (synchros dying), everything youve mentioned. His grinds into fourth, they just told him to keep driving it till the box is completely F*%$cked. New s13 boxes are pretty cheap anyways, and youd probably want second gear hey
Posted on: 2006/5/4 0:49
CA BOX
ok, good news! my CA 1200 is finally driving and quickly too but i have a small problem and i fear the answer.
Every time i try and change down to 2nd and most times i change up to 2nd it grinds like an sxe shapener! i fear that its the syncro's on 2nd and this means a box out? it doesnt do this in any other gear. any ideas boys?
Thanks
Elliott
Posted on: 2006/5/3 11:08
